20 Most Recent
Baby Lock Esante Questions & Answers
My touch screen
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
When I attach the embroidery arm and turn on the
My moms does the same. One way we got around it was to hold the presser foot all the way up and click the ok button on the screen. The other thing we did would be to hold the presser foot up all the way while turning the machine on while the embroidery unit was already attached. When I say raise the presser foot all the way up, I am talking about raising it up as if you were placing something really large under the foot, not just in the resting up position. Hope this helps - it is very frustrating! My sister has the same exact machine purchased at the same time as my moms, but she doesn't have this problem.
I have an Esante ESe2.
Since the needle broke, it could have knocked your machine out of time--requiring service. FIRST, try this: Remove the upper thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Frequently, when the thread "jumps" out of the thread path (or wraps around a guide or the spool), the thread will stitch about an inch and then break. If you watch the upper thread when you are stitching, do you see the thread tightening, tightening, tightening and then Snap?As far as the bobbin installation, you would need to consult your owner's manual.
Baby Lock Esanti ESI-2
You might want to try this solution first, although maybe your dealer has already tried it. With your machine off, hold the start/stop button, the reverse button and the needle position button down with one hand. While holding them, turn the machine on. What will come up is a screen to recalibrate your LCD. You won't need the first screen, so press the thread cutting button one time. The next screen changes the brightness level. The reverse button on your machine makes it darker, and the needle position button makes it lighter. I stumbled upon this by accident one day while recalibrating. I'd like to know if this works for you, although by now, maybe you have bought a new screen...
Touch screen
We have just launched our new website, ..although not all items are yet uploaded, they
are still available, including the LCD backlight for your Baby Lock Esante....just take a look here...
http://bargainbox.com.au/babylock/
Where do I put oil in Esante ESe Baby Lock?
one drop on the needle bar after every 8 hours of sewing, and anywhere metal rubs on metal. But this will only get you so far. the shafts will also need to be oiled and this should be done by a technician as it requires complete disassembly of the machine.
Do I oil my baby lock esante
A lot of newer computerized machines do not require oiling. Oiling improperly could damage the machine. You should probably contact a Baby Lock technician before attempting to oil your machine.
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
