20 Most Recent Baby Lock Imagine Questions & Answers
LCD screen out of alignment
This problem looks like it is the touchscreen problem, you can contact [email protected]
6/30/2019 11:39:58 AM • Baby Lock... • Answered on Jun 30, 2019
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
6/22/2016 12:21:17 AM • Baby Lock... • Answered on Jun 22, 2016
2answers
How do I replace the throat plate on my Imagine serger? It seems to not want to fit and lay back down flat.
  • Set lower blade to widest width setting
  • Place differential feed on N
  • Remove Needles
  • Place back circular hole in plate onto the anchor screw(this should never be loosened)
  • Plate will set down flush
  • Reinstall the front holding screw.
  • Reset width control
  • Check lower blade height, per instruction replacement manual.
6/1/2016 6:28:50 PM • Baby Lock... • Answered on Jun 01, 2016
How do I replace the small metal bits that hold the needles in place
Needle clamp & screw and maybe the thread guide all screw together. The screw that holds the needle into clamp is all that hold this on the machine. Don't over loosen the needle clamp screw when changing the needle next time.
6/1/2016 5:17:17 PM • Baby Lock... • Answered on Jun 01, 2016
Trying to find a drive belt to replace mine that is slipping
Search the internet by inputting the make, model, and "belt" You may have to go to a Babylock dealer to find what you need.
2/29/2016 5:38:28 PM • Baby Lock... • Answered on Feb 29, 2016
Lock button release lever won't move
Try rotating the handwheel slowly till the lock button clicks out. It should thread while it is locked on the left side though
9/9/2015 9:42:36 PM • Baby Lock... • Answered on Sep 09, 2015
2answers
Sews too fast
Have actually solved the problem now. there is an on line page which describes pulling the foot switch apart and adjusting the speed control slider for a BabyLock Evolve machine and this solution worked perfectly for the Imagine despite dire warnings from the importer not to do this. Babylocker
8/10/2015 2:21:07 PM • Baby Lock... • Answered on Aug 10, 2015
2answers
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
3/3/2015 8:36:13 AM • Baby Lock... • Answered on Mar 03, 2015
Cutter blade remains locked.
when you release the blade, sometimes you have to reengage it manually, turn it to unlock, machine off (safety only) push up on bottom of upper blade until it stops. turn hand wheel and watch if blade is moving. If not repeat. When it moves your good to go.
12/3/2014 8:31:42 PM • Baby Lock... • Answered on Dec 03, 2014
What would cause by screen to go dark on my baby long crown jewell
Could be many things, I would check the Power supply on the left of the machine when you stand in front of it. Turn off power first, then remove 4 screws power supply will come straight off. look at attached wires and make sure all are attached firmly. If that does not fix it, take it to a service man.
12/3/2014 8:14:51 PM • Baby Lock... • Answered on Dec 03, 2014
2answers
Automatic threader does not take the thread. I
Open the front cover and raise presser foot to release all threads. Depress the machine lock button firmly with your left index finger. At the same time manually rotate the machine hand wheel slowly forward until he button "snaps" into the locked position and the lock button release lever moves to the far left.
11/8/2014 4:08:12 AM • Baby Lock... • Answered on Nov 08, 2014
0answers
Babylock stuck
Be the first to answer 6/7/2014 3:45:46 AM • Baby Lock... • Posted on Jun 07, 2014Be the first to answer
Could you send a picture of what the blade and hook look like when they are put back correctly I think this would help. I think I may have put it back together incorrectly
The Baby Lock Imagine overlocker/serger is so easy to use and set up, you'll love it! The blade should be flush with the sewing bed when installed correctly. I'm not sure which part is being referred by "the hook", can you elaborate ... is it the loopers?? Here is the address for the manual http://pdfretriever.com/ref_sien.php?ID=2411572&lg=E&src=8
5/7/2014 12:32:04 AM • Baby Lock... • Answered on May 07, 2014
I need a visual on how the thread cutter looks when put back properly together
This was the best video I could find on the machine, I don't know anything about sewing machines but this might just help you. https://www.youtube.com/watch?v=q-okTBWAHMs&list=PLsmrvZ1PDyoN-cFLYrfx8ovktM6PNo5RQ
5/1/2014 3:07:11 AM • Baby Lock... • Answered on May 01, 2014
Sewing Machines Logo
157 questions posted
Popular Products
Top Baby Lock Sewing Machines Experts
vince
NOEL
NOEL
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Baby Lock Sewing Machines
Most Popular Question
imagine serger 39 s threading ports
  • Sewing Machines
