20 Most Recent
Singer Inspiration 4210 Mechanical Sewing Machine Questions & Answers
Abri mi maquina y no puedo empezar a usarla porque
Creo que tiene que soltar el tornillo y darle media vuelta para ponerlo al lado. Tambien asegurese que esta bien ensaltado todo el recorrido del hilo. Tambien puede ser la tension, pruebe de poner mas o menos tension.
11/21/2017 5:30:05 AM •
Singer...
Answered
on Nov 21, 2017
Bobbin winder on a Singer Inspiration 4205/4210 isn't winding
Are you looking at your instruction manual? If, you cannot find it, go to www.singerco.com, support and download a free one. I don't see how it won't move to the right if you have it inserted correctly and feeding the right way, look at your book.
10/12/2017 10:27:05 PM •
Singer...
Answered
on Oct 12, 2017
Singer inspiration. When using
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
2/10/2016 7:56:21 PM •
Singer...
Answered
on Feb 10, 2016
How to remove the bobbin plate?
Download the user's manual from the Singer site, www.singerco.com. It is a free download. Look on page 34, and it will show you how to remove the plate and clean underneath. There are two levers that must be set to release it.
2/10/2016 6:42:54 PM •
Singer...
Answered
on Feb 10, 2016
The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
2/10/2016 6:42:10 PM •
Singer...
Answered
on Feb 10, 2016
When I try to use
I was just looking at page 27 of your manual, and was wondering if one of your pins is broken off and that is why it won't lock in place. Take a look at it and your manual and see if that is the problem. Then call Singer at 1-800-4singer and see if they will send you another one. If, it is the first time you tried to use it, I am sure that they will help you for free. It probably was damaged when you got it.
2/10/2016 6:41:50 PM •
Singer...
Answered
on Feb 10, 2016
