Plug the headset into a powered USB port with an USB charging cable. » LED turns white during charging and turns off when the headset is fully charged. Tip • Normally, a full charge takes three hours.
Clean battery connections, and/or check the battery to see if it retains a full charge. Fully charged batteries are normally holding a 13volt charge, and up to 14.5 volts will show on a gauge during charging
1Remove the bolts and nuts that secure the center console around the gear shifter with a 1/4-inch drive ratchet, a metric socket and a Phillips head screwdriver. This will expose the rubber boot. Pull back any carpet as needed to make room for the rubber boot to be pulled over the gear shifter.
Turn the gear shifter knob counterclockwise to remove it from the top of the gear shifter. Pull the rubber boot over the gear shifter and place it on the floorboard.
Loosen and remove the retaining bolts at the base of the gear shifter with the ratchet and a metric socket.
Remove the gear shifter retaining ring with the pliers. Once the retaining ring is removed, you will now be able to pull the gear shifter lever straight up through the console hole. Inspect the bushing on the pivoted area at the bottom of the gear shifter lever. Remove all of the damaged bushing from the bottom of the gear shifter lever with the pliers.
5
Place the new bushing over the pivotal ball end of the gear shifter lever. Hold the gear lever with one hand and twist the bushing onto the ball end with your other hand until the bushing locks in place.
6
Reverse the same steps as outlined above to reinstall the gear shifter assembly and the center console assembly. Make sure that all of the retaining nuts and bolts are tight.
could be. oNe thing to try is let the battery die completely. Then try an overnight charge. If it still works the same, then the battery has bad cells and will need to be replaced. Good Luck.
That volvo and most of modern cars today uses a small explosive charge, placed in that retaining gear of seat belts. It will be activated to a collision.
To activate that seat belt, you must replace the whole retaining gear with that same type of safety precaution system.
The only way you could get a cheaper normal seatbelt is to replace it with an ordinary retaining gear lock, mostly Japanese seat belt or the older pre 1990 type that has no explosive charge.
Hope that clears everything and tightens up your problem!
Your battery is fu.k.d up. This thing ships with half a charge and your supposed to fully charge it before first using it. Even though every genius out there will say that these batteries don't retain memory charge. They are wrong. You have set your battery memory to say full when it is only 1/4 fully charged. Take the thing back to the store and exchange it for a new one if your within your 30 day window. Take the thing back to the Apple store and exchange it out for a shiny new one if your within your 1 year window. You don't need a receipt at the Apple store, cause they can just look on the back of the ipod and type in the serial #. That tells them if the ipod was sold within the year or not. Apple won't exchange the thing out if you dropped it hard or exposed the thing to liquids.
it is possible to send it a request(email or call )before u have to specify very clear about the problem otherwise try first to charge fully and discharge it 2/3 times (u also have the manufacturers/products guarantee on some parts outside the guarantee teh product is buyed)
Try this: disconnect the player from the computer, turn it off,
hold in the volume + button, and reconnect the player to the computer
while holding the volume + button in. Keep holding the volume + button
for an additional 5-50 seconds. Windows should eventually go into
recovery mode and revive the player- it will pop up a window that says
Found New Hardware Wizard.
Then recharge for 3-4 hours only - charging longer may lead to problems
