Apple MacBook Pro Notebook Logo
V
Vlado Bevc Posted on Nov 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
An e-mailitem ties up the laptop and cannot be deleted/removed. The laptop must be restarted when this happens in order to operate
Darren Means
Level 2:
  • Expert 46 Answers
  • Posted on Feb 22, 2016
Darren  Means
Expert
Level 2:
Answers
46
Questions
0
Helped
5675
Points
152
You should also try turning off the remote content feature on your mail server. Start mail then in the task bar at top click mail> preferences> viewing.then uncheck the box as shown in the photo.
an e-mailitem ties up the laptop and cannot be del - 25957821-jl5mmwysc0pla1dndybfxmtc-2-1.jpg
Louise Nadon
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Feb 15, 2016
Louise Nadon
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
665
Points
5
Have you tried deleting the item through a web-based client instead of mail or some other email client on your mac? This has worked for me in the past.
An e-mail item ties up the laptop and cannot be deleted/removed. Laptop must be restarted in order to operate. How to fix this?
An e-mail item ties up the laptop and cannot be deleted/removed.ok if it is email it is not stored on your computer it is located on your email server but the email had a bug when you opened it so after a reboot check add an remove programs for Problemsomething it put on you computer like a browser add-on or free coupons
tip
How to remove Run DLL Error on Startup
We normally face this problem that an error pops up whenever it wants
This normally happens because of some scheduled tasks in the operating system that you are unaware of .
Install Autoruns let it scan then find the exact path (as in your first post) and delete it. Reboot and see if you get the error message.
In order to scan these unattended , hidden tasks , please follow the below mentioned link to scan the Windows Sysinternals . And the file which is showing the error mostly shows up highlighted in yellow colour so its easy to identify .
https://technet.microsoft.com/en-gb/sysinternals/bb963902.aspx
Extract and run the application .
Delete the file that you get in Yellow Colour by the error and delete it .
Restart your computer and see if the problem is resloved .....
on May 17, 2016 • Miscellaneous
tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 • Computers & Internet
1helpful
2answers
How to delete operating system .
When deleting the operating system you have to have a restore disc or the master disc for an Operating System to be re-installed again. You will then have to insert the Operating System disc in the drive and then restart select boot from CD or DVD whichever you have on your lap top then you will have to format the drive with this disc it all should just do it for you select complete install. This will wipe files currently on the hard drive and enable you to restore your machine back to its original condition as you purchased it.
You computer should be by default to boot from CD ROM first boot. If not get to the BIOS press F2 when the system first boots it will take you to the BIOS then set in the BOOT order as first boot being CD or DVD first boot and hard disc second boot. Then restart and have the Operating System Disc in. If you do not have an operating system disc that came with your computer you can get one from Dell just order it and use this disc. Do not try to install just the basic Windows because Dell has all of their drivers installed on their restore discs and you will play heck trying to get the drivers. Unless you have a legal copy of Win 7 go ahead and go for it then. Making sure to be online when installing Win 7 so that it can seek driver files during the installation.
I hope this assisted you. Thanks for using FixYa for all your questions. John
tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 • Computers & Internet
I want to restart or reset my laptop. how?
Few steps to restart you laptop, I would suggest not to restart often since it will degrade the hardware resource.
  • Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
  • Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
  • Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
  • Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
  • Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.
Else Try:
Windows start > there's a small arrow(pointing RIGHT) in the left bottom > click it and u will get ALL the Power House Options there at your Click(sleep,hibernate,shut down,RESTART,....)
I just put in new batteries. I just hit the on button... nothing happened. It wasn't woking before so I thought the batteries were dead.
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
1helpful
2answers
CD/DVD drive doesn't work
try removing the drive from the laptop, then go into the device menu and delete the drive. Restart. Shutdown again and insert the drive, restart - it should show a "new device" recognized. If it doesn't, the drive may just have failed. I've had it happen to a dell drive - it just doesn't see the drive at all.
Accessing McAfee SecurityCenter; Dell Inspiron 1720
what version of MacAfee do u have along with ur laptop, restart ur laptop and open it in the safe mode and then enter ur cd of MacAfee and install it from the CD.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
