Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
SOURCE: sagging frigidaire microwave door
If your door is removable, look where there is a plastic seal or ring on the door itself. It is usually attached to a bracket or near there someplace. I have taken plastic washers and put in place, otherwise replaced the parts that are worn out on the door assembly.
Tell kids not to pull on door while in use. Harder said then done. I have 9 children and they all have done this. My youngest still thinks he can microwave GI Joe to death.
Anyrate, if the issue I gave doesn't work, try your local appliance repair store. Sometimes they can help by either repair or giving advice.
Good luck.
SOURCE: My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
SOURCE: Hi I have a
If the door is sagging, slacken the lower hinge and adjust it then adjust the catch settings on the side of the cavity by taking the cover off and lossening the screws that fix the interlock holder and with the door closed, tighten the screws back up.
Hope that helps.
SOURCE: frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Hey friend, thank you for the post!
I understand that your Frigidaire microwave door is sagging and your appliance is not working properly. You could need to a new door or hinges. These intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
