Frigidaire Microwave Ovens • Uploaded on Aug 14, 2013
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Hello blackchow - Try resetting the unit flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and return microwave. If it proves to be ineffective, the unit could possibly be experiencing a wiring failure, faulty control panel or magnetron or an issue with the power supply. Contact a professional to move forward accurately and to assist with the repairs.
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
55 questions posted
196 Questions
167 Questions
78 Questions
59 Questions
47 Questions
