20 Most Recent
Frigidaire FMV156DC Microwave Oven Questions & Answers
I have microwave model fmv156dcg.
After
If you have a smoker in the house, the display may be coated with tar from the smoke. Spray some window cleaner on a soft cloth or paper towel, and gently wipe off the display face (do not scrub; it scratches easily).
The power supply capacitor on the controller board may be going bad. Unplug the oven, remove the top/side cover, and inspect the electrolytic capacitors. The tops should be flat; if any are domed or obviously leaking, they should be replaced (note: sometimes the top of the capacitor has a thin plastic disc covering it; doming of the disc is normal). See the photo below to identify good and bad electrolytic capacitors. This photo is from a TV or computer power supply and your controller will not look this. You're looking for components like bad ones marked in the photo or the good ones next to it. If you see a bad capacitor, post a comment with the capacitance (e. g., 2200 uF) and voltage rating, and I'll recommend a part number that I know will be a good replacement. The cost is usually under $2 plus shipping from whatever supplier you choose.
It is possible that the display itself is going bad, but this is not very common.
What are its demensions
Thank you for your post, kevin l beeney!
I understand you need dimensions for your Frigidaire microwave, FMV156DC. I have located information on your microwave showing the width is 29 15/16 inches, depth is 15 9/16 inches, and height is 16 ΒΌ inches. I hope this information is helpful. -Matt
How many cu. ft.
This microwave features 1.5 cubic feet in capacity and 950 Watts of power.
The fan inside doesn't work any more. Can it be replaced?
Hey friend, that's a great question!
Based off the information you have provided the fan inside your Frigidaire microwave, FMV156DC, can be replaced. I would suggest contacting a professional because some of these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I suggest seeking assistance. One must be very careful as these replacements can lead to potential harm. -Matt
How to Install frigidaire microwave control panel CFMV1522CLB
Good Afternoon Friend,
I understand you want to know how to install the control panel on your Frigidaire microwave, model# CFMV1522CLB. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance, and should be able to replace the control panel with ease. Hope this is helpful.
-Best Regards-
WP
Cannot open door or frigidaire microwave
I understand that you are unable to open the door on your Frigidaire microwave, model# FMV156DC. Due to this being a microwave, I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to get the door open without any damage to the appliance, or harm to you or your home. Hope this is helpful.
-Best Regards-
WP
Replacing the magnetron on a microwave
Good Morning Friend,
I understand that you want to replace the magnetron on your Frigidaire microwave, model# FMV156DC. Typically, this is not a do it yourself repair, as there are no step by step instructions, and could potentially be hazardous. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine if it is just the magnetron that is needed or if there could possibly be different or more parts that are needed. Hope this is helpful.
-Best Regards-
WP
How to take the control panel off a frigidare over the stove microwave oven to find the fuses???
I understand that you are trying to take the control panel off your Frigidaire microwave, Model# FMV156DC, to find the fuses. Typically, this is not a do it yourself job, as well as there are no instruction manuals that give step-by-step instructions. I suggest contacting your local authorized technician for further assistance. They are trained on your particular model, and will be able to diagnose as well as determine if there are any parts other than fuses needed for repair. Hope this is helpful.
-Best Regards-
WP
Door won't latch & lite stays on . door hooks like spring fell off them.
I understand that you are having trouble with your Frigidaire microwave, model# FMV156DC, and the door not latching which leaves the light on inside the appliance. I also see that it looks like a spring fell off the door hook. For safety reasons, when dealing with microwaves, I don't suggest trying to repair them yourselves. I suggest contacting your local authorized technician for further assistance. They will be able to better assist in making sure your microwave is repaired correctly and there are no safety issues. Hope this is helpful.
-Best Regards-
WP
