I can't find if there's a difference between model PLMV178HC and PLMV178HCA. Every search for PLMV178HC redirects me to PLMV178HCA.
So I'm giving you information based on model PLMV178HCA. If you end up with a wrong part, the supplier has a very liberal simple return policy.
It is repaired by replacing the control panel frame assembly, which comes with a new membrane keypad already attached.
For model PLMV178HCA, that is part number
5304470533 and you can get it from
Sears online for $89.95 (subject to change).
At
my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. (Also, the service manual is
here.)
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Be very careful when disconnecting the cables & wires. Some connectors have a locking tab (see photo) Next remove the keypad strip (see photo) Then simply move your circuit board into the new frame.
Be careful, because your display tube is made of glass, and if it breaks, the board must be replaced as well.
Let me know by e-mail if I can help further.
Regards,
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
