Wait for some time to respond.if everything is not responding, u have no other option,except switching off the power supply. u should leave the system for 1 to 2 hours without switching on.then start the system. u might install extra in built fan for cooling(or) keep the system in well ventilated place.
Press and hold down power button until it turns off.
SOURCE: Acer Aspire 5520-5334
check to see if it was locked press fn and F7 to toggle between lock and unlock of mouse pad functions.
SOURCE: how do you fix a frozen mouse for a acer aspire 5315-2077 laptop?
Fn F7 probably got pressed (turns on and off the trackpad. probably the dumbest thing to have a hotkey for)
SOURCE: frozen mouse with a touch pad laptop computer
Dear MGK7,
That does make it more difficult! Okay, for future reference, when you have key control again and the mouse or touch pad stops working, if you have a standard 101 key keyboard, or even a laptop with one key instead of two on certain keys, you can do it this way:
1. Hit the Windows key, which will open your start menu.
2. Pressing the Windows key and Pause/break will take you to your system properties.
3. Minimizing and restoring screens hit Windows key and "D".
4. To get to Utility Manager, hit Windows key and "U". This will, among other things, allow you to choose to use only the keyboard or the mouse, so you can disconnect the mouse, among many other things.
5. Pressing Windows key and "F1" will take you to Help & Support.
6. Windows key plus "E" takes you to Windows Explorer".
7. Pressing "Cntrl, Alt, Delete" takes you to the task manager.
These keys should provide help in getting around in your system without a mouse.
To get to control panel, for example, press the Windows key to op[en the Start menu, and use the "up arrow" button to go to control panel.
Now that everything appears frozen, power your machine down. Remove the battery from the rear for a few minutes, even if you are operating on A/C plug in. Put the battery back in and power up. Did this make any difference?
You can always buy an inexpensive laptop mouse which works on USB. When you plug in the USB the mouse works independently of everything else. Then you could click the start up memory, help, and choose restore to an earlier time before this problem happened.
That usually will clear any problem.
Please let me know what happens.
Sirwriter
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
SOURCE: function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
