20 Most Recent
Acer eMachines 520-2890 Notebook Questions & Answers
Has acer emachines e725 microphone
If you have changed operating systems since it last worked you may need to go to Acer Emachines support site and download the microphone driver for that operating system? If you haven't changed operating systems, let us know what you may have added since it last worked? If you did change operating systems let us know which one you are running and I'll be glad to link you right to the page that has the driver you need if it's available?
Thanks,
Frank
Bios password lost how can i reset it
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Emachines g430
- Try to use Microphone on another device and check is it working there? If No! Then replace the Microphone. If its working then update the drivers of your machine.- Run Reginout scan and check is it your windows registry fine? After scanning if you found errors then fix it.Hope it helps.
Emachines d725 with Lubuntu linux, are the audio
Drivers are not independent entities they are related to the the platform that you are using as in your case its Ubuntu if you change the platform you may require to have a separate set of audio drivers.Also in most of the cases there is no need to install teh drivers manually as the latest Operating Systems can detect and install them automatically for you but in case there is an issue the drivers installers are usually provided by the manufacturers but I suggest you download the latest from the manufacturer's website.
Connection for cellph to laptop
Music, movies, photos and more can be stored on the micro
Secure Digital memory card on your Samsung Galaxy S phone.
To get all those goodies on the microsSD card you need to
transfer them from your computer. Connecting your Galaxy S to your computer is
done with the USB cable that was included with the phone and doubles as the
charging cable when plugged into the outlet adapter that also came with the
phone
Plug the large end of the micro USB cable into your computer and the small end
into the USB port on the top of your Galaxy S phone.
Wait for your computer to recognize the phone.
Press the "Power" button on the top right side of your phone,
briefly.
Unlock the phone by dragging the padlock icon to the top of
the screen.
Drag the notification pane down by touching the top of the screen and dragging
your finger to the bottom.
Touch the "USB Connected" notification and then
press the "Mount" button.
Your phone's microSD card will appear to your computer like
an external drive.
Click on the "Start" button on your computer and
then click on "Computer."
Double-click the drive icon that corresponds to your Galaxy
S phone.
This will open a folder that shows the contents of your
phone's microSD card.
You can copy files to and from the folder like you would any
other folder on your computer.
Click the "USB Device" icon in the task tray of
your computer.
Click "Eject USB Device."
Wait until you're done transferring files before ejecting
the phone from the computer.
Unlock your phone and drag down the notification area.
Tap the "USB Connected" notification and press
"Disconnect."
You can now safely unplug your phone.
Bluetooth
http://www.samsung.com/global/microsite/galaxys/userguide/connectivity.html
My laptop gets dim from startup
Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, adjust Display Brightness, Open the Advanced Power settings, adjust to your preference. On battery your laptop will decrease brightness, and other nonessential processes to conserve/extend battery time.
