When I turn on my laptop I get a message that says the primary internal battery 601 is running low on memory. I took the two things on the back off and didn't see any coin looking battery. Does anyone know where it is located?
Primary internal battery 601 refers to bios backup battery.
read this:
http://h30434.www3.hp.com/t5/Desktop-Hardware/Primary-internal-battery-601/td-p/542305
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
SOURCE: I have a new HP Laptop G56 runing windows 7, when
Try a hard reset on the router first;
Turn router around;
Find the small pinhole usually located by the power cord;
Stick something like a paperclip in it and press down firmly for 1 minute;
wait until you see the lights blink and then go out;
Then; unplug the power cord from router for about half a minute;
Then, plug it back in.
Try it again and see if it stays on.
You can also try and upgrade your firmware if this doesn't help at all.
Click this link and follow the instructions for updating your firmware.
http://forums.whirlpool.net.au/archive/322832
However; If your router is old or damaged, it may need to be replaced. They shouldn't continue to reboot over and over.
Please rate this solution if it was helpful to you. It doesn't cost anything to rate and it is greatly appreciated!
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
SOURCE: i cant find sata drivers
There are two ways.
If you bought a new SATA and get a blue screen when you install win. server 2003, you have to go to BIOS and change HD setting. (not on 1st page for sure. I have to what option you have.)
Or
You have to get it from HP, but I don't know whether they have or they will give you for free.
SOURCE: hp g56 startup
Hello have you been able to solve this I have the same HP g56 laptop with the same problem?
SOURCE: where is the internal primary battery on an HP G62 laptop
Should be the 1st removable item underneath towards the back. Look for two sliding release clips.
Here is the PDF manual.
http://h10032.www1.hp.com/ctg/Manual/c02542102.pdf
