20 Most Recent HP Pavilion dv7-1129wm Notebook Questions & Answers
Hp notebook 1000 internal battery 601
What? Laptop giving you a warning about the battery health. Suggest you look on amazon or your local computer shop near you to see if they have it or not along with the price for it.
2/18/2018 5:04:38 AM • HP Pavilion... • Answered on Feb 18, 2018
Where do i find my internal battery omy hp
I believe you mean CMOS battery. Just open the bottom plate. I give you a link. Unscrew 6 screws like in step 1, then skip to step 16 where it shows you CMOS battery. If you don't have a spare, theres loads of them in ebay for couple bucks. How to disassemble HP Pavilion dv7
6/7/2015 1:56:45 PM • HP Pavilion... • Answered on Jun 07, 2015
2answers
Internal battery (601)
This means you need to replace the laptop battery as it can't hold a large enough charge. You only see this when the battery capacity drops below about 25% of new. So instead of a few hours or more of running on the battery you may now may only have minutes.
There are several ways to get a good low cost replacement. These are usually HP batteries anyway so the difference in the price. It pays to shop around both on the net and off. As an example on one battery I was quoted about $160 from the local chain store (Office despots or something) and then I found several batteries online for $75 (exact same one) and finally I called a local battery store and they sold it to me for $77 and I didn;t have to pay shipping.
12/1/2014 10:04:46 PM • HP Pavilion... • Answered on Dec 01, 2014
2answers
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop. If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
2/28/2014 4:08:31 PM • HP Pavilion... • Answered on Feb 28, 2014
Installing windows 7 on hp pavilion d7 1120wm not permitted
I know this is common in Windows 8 PC's, never saw it in Vista. I would recommend upgrading the BIOS if an update is available from HP. Really makes no sense as Win 7 is based on Vista's framework. According to HP, they made 20 versions of this model, if you can get back to me with the complete model number (from the sticker on the bottom) that would be a big help.
2/12/2014 2:40:29 AM • HP Pavilion... • Answered on Feb 12, 2014
Battery 601
This is battery error. You should install HP assistant that will show you how much battery life is expected and condition(normal, excellent, changeable)
11/28/2013 8:25:48 AM • HP Pavilion... • Answered on Nov 28, 2013
2answers
Internal battery error 601 is displayed what is
1. This error is about the primary (main) battery, not the small CMOS one..2. You may remove the primary battery from the laptop and use the laptop as a desktop using only a power cord. The battery doesn't have to be installed in the laptop and the error shouldn't be coming back then..I would upgrade the BIOS first, it could be a bug and a newer BIOS might fix it..
10/22/2013 2:48:47 PM • HP Pavilion... • Answered on Oct 22, 2013
Bad BIOS
Have you tried to remove the CMOS battery, for a few hours, I know it's a long shot, but it beats pulling out a Mobo. While your in there reseat the Memory Mods.
12/16/2012 3:23:36 AM • HP Pavilion... • Answered on Dec 16, 2012
Internal battery for HPg71 low
Thats probably your HUB (hold up battery). Its used to keep things like setting, time, and data when you dont have your computer plugged in or your battery dies completly. Not to sure how hard it is to change on that computer but usually its pretty simple you can try hp to find the battery you need or the better anc cheaper place to get the battery would be tigerdirect.com thats what i use for all computer parts.
10/24/2012 12:39:09 AM • HP Pavilion... • Answered on Oct 24, 2012
My battery charger is not working cannot afford to buy another one help
Borrow one charger from a friend, and verify if it is reallyfrom the charger.If it is then use your warranty.
8/2/2012 5:59:58 PM • HP Pavilion... • Answered on Aug 02, 2012
I have a hp dv7 1129wm laptop and i get the leds on the keyboard and they blink 4 times for a griphic card error. how can i stop the lights from blinking?
You can stop the lights by fixing the Video Graphics Card. Otherwise it will continue to blink and not boot up.
4/26/2012 12:52:56 PM • HP Pavilion... • Answered on Apr 26, 2012
After pressing the power button, my HP dv7-1129
try taking the battery out, unplug the DC cable and hold down the power button for 30 seconds this will get rid of the static on the motherboard which could cause the problem.
After you have done this put the battery back in, then the DC cable then try to turn it on.
If not it could be your battery because you are getting an indication that you are receiving power, try taking the battery out and just plugging in the power cable.
Hope this solves the problem.
3/10/2012 5:49:39 AM • HP Pavilion... • Answered on Mar 10, 2012
The machine wont boot, when i press on it bilks
If you have the HP Computer then the Recovery has two option one is Destructive Recovery (Data Loss) and Non - Destructive (Data Back-up). You just need to Press F11 as soon as the computer restart. Then follow the on screen instruction and choose the option accordingly.
3/10/2012 5:47:20 AM • HP Pavilion... • Answered on Mar 10, 2012
When i boot my computer the screen stays blank and
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
9/29/2011 9:47:26 PM • HP Pavilion... • Answered on Sep 29, 2011
My computer will turn on,gives
hi,
Your operating system needs repair.Some files may be damaged.
Use another PC with good operating system for repair.
Remove the hard drive from your PC and enslave it on the second.
Start the PC.It will immediately start the repair process and start windows.
Turn it off and remove the drive.
Put it back to your PC and and turn the machine on.
thank you!
9/9/2011 11:13:53 AM • HP Pavilion... • Answered on Sep 09, 2011
HP Pavilion dv7-1129wm blank screen
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
8/15/2011 4:57:57 PM • HP Pavilion... • Answered on Aug 15, 2011
Dc jack broken need manual
Here is the link:
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2/14/2011 5:40:06 PM • HP Pavilion... • Answered on Feb 14, 2011
My Pavillion dv 1000 wont
If its above 2 gb most older laptops won't because the card is in FAT and not FAT 32. cards 4 gb and over are written differently you can hook your camera up to your computer and transfer then that way or purchase a HCSD card reader for higher capacity cards.
1/19/2011 9:21:59 PM • HP Pavilion... • Answered on Jan 19, 2011
I have an HP Dv7-1133cl that is giving me a error
It is called the Cmos Battery and if you browse www.insidemylaptop.com you will find how to change it.
Hope that helps.
12/31/2010 6:06:08 PM • HP Pavilion... • Answered on Dec 31, 2010
HP Pavilion dv7-1129wm Notebook Logo
40 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
dc jack broken need manual
  • Computers & Internet
