That's for Ray Gallant who thinks there's no sim card slot in a lapotp :) . It is a 3g modem build in .
About your question you will need to download drivers from
HP EliteBook 8440p Notebook PC
here for the modem . You will need to select your operation system then go to Software - Solutions > and download HP Connection Manager . If it still does not work you may try to download some of the Driver - Network drivers but i'm not sure which one will work.
i removed the battery and waited for 3 mins. it says its been resetted to default but still ask for password. is there a default password?? for elitebook 8440p i7
I don't have an elite pad, but found a little white dot in the upper left hand corner of the touch pad. Double tap or single tap , can't remember but when I did that it worked. Hope this helps.
is there a lock in the top of the mouse, if there is press it for a second and see if that works. some times depending on the mouse settings you have to be firm when pressing.
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
