Panasonic KX-T7731 Corded Phone Logo
A
Anonymous Posted on Sep 02, 2014
<!-- from fixya rte -->How to set extension names - Panasonic KX-T7731 Corded Phone
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Hi we have a Nortel T7316E. Staff change their
Hi Amy, you can change the name for an extension, but it will change the name for the extension for all the phones.
It is best to do programming on a T7316, M7310, or an M7324
1. Feature **23646
2. Password: 266344
>>>your password may have been changed by your phone company. contact them for the password.
3. Scroll to General Admin
4. Go to Names
5. Select Set Names
6. Enter in the DN of the extension you would like to change
7. Use the dial pad to change the extension.
8. Press Rls when finished (handset with arrow facing down)
Hi We have a Nortel T7316E phone system. Staff
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344 (with the handset in its cradle).When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on. (i.e 202)
Then press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name(Traci).
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Winston = 9 -> 4,4,4 -> 6,6 -> 7,7,7,7-> 8-> 6,6,6-> 6,6
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
How to program an internal extension number and then give it a name by using alphabet how to change a name tag on an existing internal extension number
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display say Name.
press the Chng soft key. (or the clear key to erase)
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
I NEED TO FIND SOMEONE EXT.# WHEN THEY CALL ME IT SAYS THERE NAME BUT I NEED TO KNOW THE EXT#
You can either do a button inquiry in each of the extensions to see which extension number is associated with which name. that is done by going to each set and pressing feature *0 then pressing the intercom key. or you can look through set programming to find out.
The display should now ask for an extension number. Press the list soft key.
It will list the extension number followed by the name for the first extension.
Press the next key for the next extension (bottom right arrow) .
Rename file extensions
To display file name extensionsDepending on your settings, the file name extensions of your files may not be visible. To display the file name extensions of your files if they are not visible, follow these steps:
  1. Open My Computer or Windows Explorer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab.
  4. In the Advanced settings box, click to clear the Hide extensions for known file types check box.
  5. Click OK.
Hope This Helps, Please Rate My Response! Thanks! Prem
The resource cannot be displayed The page you are looking for cannot be opened by your browser because it has a file name extension that your browser does not accept....
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, make sure that the Accept header of the client request matches the MIME type that is specified for the requested content file name extension on the server. To do this, follow these steps: 1. Start IIS Manager. To do this, click Start, click Run, type inetmgr.exe, and then click OK. 2. In IIS Manager, expand the server name, expand Web sites, and then click the Web site that you want to modify. 3. In Features View, double-click MIME Types. 4. Double-click the MIME type that you want to modify. 5. In the Edit MIME type dialog box, type the appropriate MIME type for the content file name extension in the MIME Type box.
Note You can also set the MIME type of the content file name extension to */* to accept any MIME type
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8helpful
4answers
Changing the names on extensions
Fuction
266344
Pw: 23646
Terninals & Sets
Show set: (type your extension in)
Your extenstion shows: Your Name or Name You want to Change
press top right Arrow button
Capabilities...
Bottom right Arrow button
Name:
CLR Change
Press Change, then use the keypad to type in new name
Prees bottom Arrow Button again, then Release button.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
