Where is the auto document feeder located on the mg5422
SOURCE: Document in ADF Redo operation after checking document in ADF and
UPDATE..............
I Solved the problem....
The problem is in the gear box on the document feeder......The (Poor Quality) tension spring against the gear harness becomes stressed to the point where it bends out of it's 90 degree angle from (FYI - below average) use . It fails to function properly causing mis-alignment of the gears during document loading.
In order to fix this you need to remove the drive motor, gear housing and some gears. Bend the tension spring back to the correct 90 degree angle. and reassemble it again. Not for the impatient person.
SOURCE: Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
SOURCE: Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
SOURCE: Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
