Gate motor was installed 09/2010 and weight +- 90Kg.Now gate opens +-2.5m but when closing it only moves .3m opens again and closes .7m. Keep doing this and after a few minutes gate is closed
SOURCE: Latch for hatch of my '07 Subaru is closed with gate open
Unfortunately, you will have to remove the panel of the door, Use flathead screwdriver to pry open. It is very likely the spring fell off.
SOURCE: tail gate stuck closed
Hi;The latch/ouside handle is held on by four bolts on the inside of tailgat. Remove the four bolts and the handle should come clear so you can see the mechanism. Your on you own now.
SOURCE: LIFTGATE OPENS NORMALLY BUT ONLY CLICKS WHEN TRYING TO CLOSE
Sounds like bad spot in gear,will require replacing mechanism.
SOURCE: The
The lift gate latch is at fault the switch contacts in the latch are worn out replace the liftgate latch and your problem is solved
