I want to add more memory. what specs should I look for? Thanks
Your machine has 4 DIMM slots. They use PC3200 (DDR400) DIMMS (184-pin). The machine comes pre-installed with 2, 256MB DIMMS providing 512MB of RAM. The largest DIMMs available in the DDR PC3200 are 1GB. If you keep what you have, you can add an additional 2GB of RAM, for a total of 2.5GB. If you are running WINXP 32-bit, this should be more than acceptable. You can replace all four DIMMS and get 4GB of RAM, but a 32-bit OS can only access a little of 3GB of RAM. If you want to come close to maxing out under a 32-bit OS, remove one of the installed DIMMS and add 3 1GB DIMMS. These are old memory and may be hard to find and actually cost more than newer memory.
