20 Most Recent
ASUS P5GV-MX Motherboard Questions & Answers
Have installed windows 7 but having probs with VGA ... There is none ....
This motherboard has Intel graphics built in. I assume you were using a PCIE or PCI plug-in graphics card which is not working since you installed Windows 7. Swap your screen to the built-in VGA adapter on the motherboard and re-boot. Then download Windows 7 drivers for your video card. If this is not the problem, go to your BIOS settings (if you can) and reload default settings. If that doesn't work, plug a known good VGA card into an expansion slot and re-boot. Then proceed as above. Never add or remove cards while the computer is plugged in to power. Good luck!
Cheers, Don
Download manual
You can download the complete instruction manual in PDF format by clicking this
link.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
I install new processor of
ASUS P5GV-MX motherboard only support
Intel Pentium 4 / Celeron processors. It will not support Core 2 Due processor.
Thanks for using FixYa.
Asus p5gv-mx mtherboard driver
Select which OS you are using and dowload thru the below Link.
http://support.asus.com/Download.aspx?SLanguage=en&m=P5GV-MX&p=1&s=22
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
I have a asus p5gv-tmx/s
hi
go to following link you will get your drivers
http://nodevice.com/driver/P5GV-MX/get34070.html
How to download Asus P5GV
Get it from here
http://support.asus.com/download/download.aspx?SLanguage=en-us&product=1&model=P5GV-MX&type=map&f_type=1
