20 Most Recent
Compaq CPQ SR1802HM PRESARIO DESKTOP COMPUTER (DERIVATIVE) (ER910AA) Questions & Answers
Media player
if it is the only process that freezes up you should re-install your "ripping" software. If the whole computer freezes up you need more ram or need to free up some memory. You may have too much going on when ripping.
How much memory can I ad to a SR1802HM computer
Maximum allowed
4 GB* (4 x 1 GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less
Maximum allowed
*Actual available memory may be lessThere will be 4 slots for the memory, you can use 4 memory cards of 1 GB each meaning thereby u can use 4 GB maximum.
You dont need a extras Hard drive That someting else .. Hard Drive and Memory are two differente Thing... Go on the Net and Exemple... Type Compaq Presario SR1802HM.. Manual & Spec, You will get all the information your need for it ....
No video and constant long beeps
Hi ,
if there is no display get with on bord display please reset COMS setting by unplugging COMS battery ....
then if u want to install external AGP card in u r pc u need to disable on board display in COMS setting ....Do it ..it should be working fine ..
If this information is useful for u please rate me.......
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
