SOURCE: New lamp, still says "Lamp Approaching End of Life" message
Did you reset the lamp hours in the menu? I believe it checks lamp life by how many hours it has been used.
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
SOURCE: Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
SOURCE: Flashing standby,power on,lamp lights with no fan
Most problems with the lamps are covered in the manuels for these projectors , however none user technical difficulties are not .. ie where it is needed to open the unit not recomended to the untrained as a screwdiver in the wrong place can cause irepairable harm let alone death ?
To check if it is your bulb simply take the unit to an engineer for an estimate usually free at least you will know whats wrong and can go from there .. and if you do have a working bulb an ebay replacement is probably the cheaper conclusion to your problem ... regards Vortash
SOURCE: optoma DX605 hard reset
Have you tried going to Menu>Options>Lamp Settings>Lamp Reset>Yes?
Hope this helps!!
