20 Most Recent
Optoma DX605 Multimedia Projector Questions & Answers
Optoma ex530 screen goes dark
possible the condenser lens or light tunnel goes bad.firstly try to clean it, if no helpful, you have to replace it.
Get a blinking green light
Flashing green light means fan is not working.Check for the fan power supply and lamp is working and replace it if not working.Check for the fuse from the power cord and check if it is working.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
My fairly new dx605 is showing everything grren on
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
We have an optoma dx 605 that won't turn on
It may not be...there is always a fuse in the power supply section that you can check to see. If you can remove the casing and locate the power supply you will see a fuse it is very close to where the power cord is connected at. If not capable you can at least invest in an hour labor for someone to let you know.
Need power supply unit
Optoma fixes all their own equipment. They have no dealers as far as I know...
This place says they can fix it. They may have parts. Offices in California and Georgia.
There is no picture when i hit the power. the lamp
Just from your description, the problem sounds like a "ballast" problem. That's the circuit that controls the lamp. It initially ignites the lamp and then keeps it burning. Just to be sure, remove the lamp and inspect it. There should be no dark spots on it or bulges, etc. Since you have a new lamp, chances are low that it would be bad--if possible, return to where you got it from and test your projector with a known-good lamp. Classic ballast failure symptoms are just what you described...Is the projector under warranty?? Normally the ballast is over 100 to several hundred dollars depending on make, model, etc...Rick
My dx605 projector's colors go haywire after 15 min of use
You should check the projector's settings to make sure you haven't accidentally altered the colors. Most computers allow for color distortion to be implemented on your display devices.
Go to Control panel, select personalization, and then click on Color Management. A number of profiles will emerge, and you will have to go through to make sure your color settings are correct. You should also go to your driver suite, which is provided by whomever manufactures your graphics card (ATI, Nvidia, or Intel), and check the color settings there, as they may have taken over the color control on your computer.
