I was unable to access my state so I hit the change country box. Now I can not get back to US.
SOURCE: Changing Country
hello i got new garmin am having blouetooth troubleshooting is any way u can helpe me please/email [email protected]
SOURCE: I just turned my Garmin
What you want to do is a factory reset to clear the user data.
1. Turn the unit off.
2. Place your finger in the lower-right corner of the screen.
3. Keep your finger there and turn on the unit.
You will be asked if you want to erase all user data. Select yes. Your Nuvi will restart and ask you the country information again.
- Jim
SHARCNET-USA
SOURCE: same- how do you reset the default country?
Achieve global reset by pressing down on the bottom right corner of the touch screen (i used a pencil eraser) while restarting the GPS. You will default back to factory settings and can re-select your language of choice then.
SOURCE: how do I change countrys on my garmin 775t,I'm
Contacted the garmin helpline and they were very helpfull.
Thank you
pfcooney
SOURCE: How do I change the country on my Garmin nuvi 255W?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Stuff happens. Try this:
This may be a result of a previous software
version on a device or possibly some one changing the settings. If a device
does power on with a foreign language that you can not understand it can be
corrected by going through the settings to change the text language.
To change the text language:
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs
loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language
needed, please selected the desired language
