Input/output socket broken. I could attempt a repair myself if you could tell me where to get a replacement.
SOURCE: Gqrmin 350 GPS Receiver wont turn on
i have a 350 garmin and it when i put in a name of a place it says no matches found??? how can i fix that???/
SOURCE: Garmin nuvi 350 - broken screen
If the LCD is actually leaking (big stain on the screen) then it cannot be repaired, only replaced.
Replacing an LCD is a relatively simple job on any GPS, it is normally just a case of opening the casing, disconnecting the ribbon cable on the old screen and putting the new one in its place. As long as you are careful and put everything back where you found it then you should have no problems.
You can check all the parts suppliers in your area or online for a new screen, but for the lowest cost solution I would suggest searching ebay for a faulty nuvi 350 with an intact screen. If you can find one you will probably get it for less than the cost of a new part, plus whatever bits you have left you can always resell. There are always people wanting to buy spares for satnavs.
SOURCE: Garmin Nuvi 760 needs repairs
Here is a US company which fixes broken Garmin screens.
http://www.sharc.net/nuvi_LCD_repair.htm
I have no affiliation with this company.
SOURCE: Garmin Nuvi 660 cradle socket is broken.
I called Garmin at 1-800-800-1020 and spoke to a customer service rep. Indicated I was driving down the road and the GPS fell out of the cradle socket...which the GPS could have broke. They said no problem and are sending me a new cradle socket at no charge. Good Luck.
