How do I correct and/or enable the TWAIN Functions with my driver? I have done several clean installs of the driver but I am still getting the same error. can you help?
SOURCE: Vista/Lexmark nightmare Installing?
everyone seems to have the same problem with lexmark printers .it seems that lexmark have violated the trade description act by stating that there printers are vista compatable which they clearly arent .according to the varius websights i have just visited there are a lot more than 7 disgruntled lexmark customers. ian from lexmark has stated it will be one or two months before the correct software is available . two months from when? it would be interesting to hear if guest jan 17 has received his disc from india yet, ev posted jan 24
SOURCE: scanner won't work do to
Andi2009,
Thank you as I followed your idea and it worked like a charm. thanks again! All with the same problem please do the same! It will work!
SOURCE: Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
SOURCE: Gets error related to lxdnlscn.exe when I push the scan button on the printer.
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
First, unplug the USB cable. Next, please download the clean up patch from the link given below:
ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/
Click on "CleanupUtility.exe" file.
To apply the cleanup file, copy and paste the icon on to your desktop and double click the file to run the file.
Please download and install the Windows Vista driver from the website given below in order to resolve the issue:
www.lexmark.com
Please click on "Drivers & Downloads."
Select "Driver Finder" and under "Search by Model" Please enter the printer model number "Lexmark X2690" click on search.
Please use the following steps to download the Lexmark X2690 Vista driver to your desktop:
1. Select "vista_x64" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark X2600 series printer and scanner drivers.
SOURCE: Lexmark registration reminder pops up everytime i
64-bit.exe is only for 64-bit vista, not 32-bit, so it will not work! you have to track the registry reminder portion of that lexmark you have down. regedit its registry entry so it cannot autostart. will be looking for details.
