20 Most Recent
Nextar Q3 GPS Receiver Questions & Answers
Nextar gps update
Here is a proposed solution. We nextar owners who purchased this, not just for the low price, but for the many selling points. one of which is the ability to "update very soon". This constitutes a deceptive sales practice. Thereby, it is a fraud. This is illegal.
That leaves us consumers with one option. That option is to File a lawsuit against Nextar and their licenced retailers.
We need to band together, organize as a consumer group and either force nextar to comply, or we sue for the cost of a new unit from another company, plus punitive damages.
We as consumers can not continue to accept abuse like this from large corporations.
Need to buy Ac adaptor & Car adaptor
i found best buys has alot of gps units with ac and car adaptors or the fast way to go is google it just punch in the product and model then search it
Intellinav.exe application error
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Need new battery for Nextar gps yoku battery 3.7v
eBay... 3.7v generic lithium polymer battery. Check dimensions to make sure it will fit inside your device (most sellers have a pic with the dimensions of the battery). Solder red to red and black to black.... Reassemble device, and your done.
Application error sky caddie sgx
HelloThe problem post is seems to be difficult to understand. Will you please give me a brief description about the fault with your Sky Caddie SGX?
Is there support for nextar
No there is no more support for nextar units. Their website www.nextargps.com and their tech support phone number both are no longer available.
Problem: get message saying, "Database
The card is not compatible with your nextar.Try any other card and reconfirm, is it card problem or nextar.If the nextar is saying same error for all card then its software error for nextar.Get the nextar firmware updated from nextar website online.But first try with any other car too.Also clean the socket where you insert sd card.-------
This should help.Thanks.Helpmech.
Cant down load anything
The minimum requirements may call for USB 2.0, And not the older, slower 1.1, some devices will work with both, and some will not, the easiest way to tell for sur is to hook it up to another newer PC and if it works then you know you need to upgrade your PC with some usb 2.0 ports, NOT JUST A USB HUB, this is an internal upgrade. Thanks for the fixya rating if this helps.
