20 Most Recent Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Questions & Answers
If you open the panel where you replace the ink cartridges there is a square hole directly behind the control panel. The area gives you enough space to put your hand under the plastic and you will feel what I only describe as a plastic latch, pull it and you should feel the control panel loosen to then be able to close.
Hope this helps...
Lexmark Prospect... | Answered on Nov 29, 2019
open the laptop and under the control panel tab you will see printers and devices
click on that and at the top click on add a printer
click on the local printer
connect the printer and switch on
follow the installer wizard directions
Lexmark Prospect... | Answered on Sep 23, 2016
Go to the Lexmark support site and download the needed software from there.
A firmware update for the Lexmark Prospect Pro205 printer address print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After successfully updating your printer, try to print a document again to verify that the problem is fixed.
Should the problem continue even after the update, please contact Lexmark Technical Support Center for further assistance. Thanks.
Lexmark Prospect... | Answered on Aug 27, 2016
I'm in the same boat with my Lexmark Pro208! This sucks!
Lexmark Prospect... | Answered on May 31, 2015
Call 1-800-LEXMARK (800-539-6275)
Lexmark Prospect... | Answered on Feb 06, 2015
Sounds like you need a new one. The best place to buy is amazon (because of reviews and price). take a look Lexmark Printhead cheers
Lexmark Prospect... | Answered on Nov 25, 2014
I have to do this every time I try to print more than one job. Why is this happening? It is very time consuming to restart the pc every time you have to print more than 1 job.
Lexmark Prospect... | Answered on Nov 22, 2014
Step one, do a deep clean printhead, which if you have a touch panel on the printer, go to the ink the ink menu - on the top right of the printer panel, press More Options - then choose the option Deep clean printhead.
If you have a non-touch panel printer, press the Setup button, and go to the Maintenance menu, then choose the option Deep clean printhead.
If this doesn't fix it then you may need to update the printer firmware. Here is a link:
Select your Printer Firmware
If that doesn't fix the problem then let me know.
Lexmark Prospect... | Answered on Oct 09, 2014
You'll have to enter the printers MAC address in your wireless router.If you don't have a wireless router then you'll have to buy one.
Lexmark Prospect... | Answered on Sep 25, 2014
The printer takes A4, Legal and letter size paper.
see the specifications at this site.
Lexmark Prospect... | Answered on Sep 15, 2014
The trouble with most of the printer ink cartridge manufactures is that they have for a number of years made it harder to refill cartridges and want you to buy them new. It will depend on what model of printer as there are certain cartridges that can be refilled only for that model. Also what can affect your being able to refill cartridges is if your printer has had an update to it's own software, not the driver software.
Lexmark Prospect... | Answered on Aug 14, 2014
may be there is problem with paper path sensor faulty or maybe broken or may be the problem with power of the paper path sensor there should be 5v dc present on sensor
Lexmark Prospect... | Answered on Jul 14, 2014
I would try opening the printer up and blowing it out with a can of air really well , unplug it and then see if it corrects the problem .... if that doesn't work I would call Lexmark's 800 # they are always very helpful!
Lexmark Prospect... | Answered on Jul 07, 2014
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
200 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
problem printhead
  • Office Equipment & Supplies
