Televison & Video Logo
l
larry wade Posted on Mar 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv turns on but screen stays black, all sounds can be heard when the cable box is turned on also
Is it the backlight? and how do you replace
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Mar 24, 2014
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008720
Points
237762
Yes. It is the fault with its back light inverter. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
2answers
My 40in SEIKI TV turns on and the screen goes black but has sound
Here are a few suggestions for troubleshooting:
  1. Check the connections: Make sure that all the connections between your TV, cable box, or streaming device are securely plugged in.
  2. Check the settings: Make sure that the TV is set to the correct input, and that the cable box or streaming device is set to the correct output.
  3. Check the backlight: Some TVs have a backlight setting that can be adjusted. Make sure that the backlight setting is not turned off or set too low.
  4. Check for a firmware update: Check if there's any firmware updates available for your TV and make sure that it's up to date.
  5. Check the cable: If the cable that connects the TV to the wall outlet is damaged, the TV won't turn on. Try unplugging the TV, waiting a few minutes, and plugging it back in.
  6. Check the T-Con Board: T-Con board is a small circuit board that connects the LCD panel to the main board. It could be malfunctioning, which is causing the image not to display.
  7. Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer for further assistance, your TV may require repair or replacement.
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
When you turn it on tv screen turns blue then black
If it stays black and you have sound I would guess your backlight is bad and needs replacing.
You can get get parts for this tv at www.interliquidparts.com
Had the LCD TV For 5 Years, no problems, then just before going to bed i was about to turn off the tv when the screen went black but sound was fine. I switched channels and you could hear the channels...
Your problem can be related to either LCD backlight inverter failure or T-con board failure. Please turn on your tv, darken the room and see if you notice a dull glow on the screen. If you see a dull glow then backlight is functional and the t-con is dead. Otherwise it can be a backlight inverter failure(in some cases the backlight itself). In that case I would try replacing the backlight inverter board and hope its not the backlight as the backlight is embedded into the the panel and the only way to replace it is to replace the panel.
2answers
My LCD HDTV screen keeps going black.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
