20 Most Recent
Panasonic TH-50PX60U 50 in. Plasma HDTV Questions & Answers
Permanent horizontal black lines on my 50
Ive got bad news for you, about 90% of the time black horizontal lines are caused by the panel failing, your going to need a new TV. You can try replacing the timing board but the chances of it fixing it are slim..
1/7/2018 8:12:21 PM •
Panasonic...
Answered
on Jan 07, 2018
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
10/9/2015 6:13:48 PM •
Panasonic...
Answered
on Oct 09, 2015
Black Screen. Will display dvr recordings but will not display tv channels.
if it will bring the menus up from the remote also it soundss as though the receiver has gone. Maybe that should be the tuner.
You appear to need the services of a technician to diagnose.
Before you do that reset the tv to factory default and set it up from scratch . Also check that the aerial/amtemma omsta;;atopm os pl.
7/5/2015 12:26:07 AM •
Panasonic...
Answered
on Jul 05, 2015
Red light blinks on panasonic 50" Plasma TV, will not turn on
These blinks are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
10/11/2014 4:41:30 AM •
Panasonic...
Answered
on Oct 11, 2014
Panasonic fault codes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
8/23/2014 10:49:40 AM •
Panasonic...
Answered
on Aug 23, 2014
