20 Most Recent Samsung UN65C8000 TV Questions & Answers
Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/1/2015 2:11:18 PM • Samsung... • Answered on Nov 01, 2015
How to fix Vertical line on the screen led tv?
tv model number is important for solution please writhe brand name and model number thanks for joining fixya!
6/3/2015 5:32:22 AM • Samsung... • Answered on Jun 03, 2015
Un65c8000
Is this a Samsung TV? Can you post a picture of the distorted screen?
4/18/2014 12:37:46 AM • Samsung... • Answered on Apr 18, 2014
TV does not turn on, has continuous clicking sound
Check for any short circuited component/s at its main board.If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/11/2013 9:14:19 AM • Samsung... • Answered on Nov 11, 2013
My new Samsung UN65C8000 LED TV has an
You did not say if the first one went back for the same fault. If it went back for a different fault then this set is faulty! If not then unless it it more susceptible to RF interference possibly mains borne than the flawless set (that is possible) and you have some other equipment in the house which is radiating like a power supply or dimmer or whatever, it must be faulty. Turn everything in the house off just to be sure nothing is causing interference. Even then it could be picking up interference from elsewhere. What affects it or does it seem random (position time of day etc.)? The only way to be truly sure is to try it in another location
If it's new why not return it?
2/16/2011 1:08:36 AM • Samsung... • Answered on Feb 16, 2011
I have a Samsung TV. Model UN55HU7200. When try to turn it on the red indicator light at the left bottom flashes and i can hear a Click -Click then flashes then click-click.
Sounds like a power board issue. Unfortunately this is a common problem in flat screen TVs. Typicality this happens after the tv is three years old or older. Some will last several years. The repair is almost cost prohibitive. The replacement board if you sent it out to a repair shop would cost approximately $190.00 and altleast two hours labor $180.00 for the repair. Most repair shops also charge for a diagnostic fee. That fee most likely would be around $50.00.
1/18/2019 11:52:57 PM • Samsung UN... • Answered on Jan 18, 2019
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM • Samsung UN... • Answered on Oct 27, 2017
Samsung UN40JU6500F had picture on intial power up, changed source and lost picture. Can't get it back, only sound. See faint images. Bottom back shows blue lights on. Inverter? Power board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/27/2016 2:10:32 AM • Samsung UN... • Answered on Jul 27, 2016
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/1/2016 4:33:08 PM • Samsung UN... • Answered on Apr 01, 2016
2answers
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
5/30/2015 2:13:51 AM • Samsung UN... • Answered on May 30, 2015
2answers
I got a 55 inch Samsung flat panel tv model # UN55D6000Sf Version H302 with standby light blinking 1 time in repeat. I have changed the power supply board, main board & tcon board but still no luc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. 25385779-zvi5jbxfx450ftsjwzjui5ep-5-0.jpg
5/30/2015 2:11:49 AM • Samsung UN... • Answered on May 30, 2015
3answers
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
5/30/2015 1:36:41 AM • Samsung UN... • Answered on May 30, 2015
HOW DO I UPDATE MY SAMSUNG LED TV FIRMWARE MODEL NUMBER UE46B8000XWXXU
Try opening your menu options and search for "updates" Usually when you set your TV for the first time it usually guides you to do this firmware update. Try acting like your are setting up your TV for the first time and maybe it will have a option for this.
4/3/2015 2:02:30 PM • Samsung UN... • Answered on Apr 03, 2015
LED TV strobing
new hdmi cable
9/8/2014 3:19:06 PM • Samsung UN... • Answered on Sep 08, 2014
0answers
Samsung ln60d60 frezzes every 10-20 seconds
Main digital board fault. Contact the authorized service center for Samsung. Gopakumar Gopalan Google
5/19/2014 3:08:13 AM • Samsung UN... • Answered on May 19, 2014
0answers
0answers
Samsung UN65C8000 TV Logo
Popular Tags
6 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
UN Samsung
  • UN Samsung
Most Popular Question
fix vertical line screen led tv
  • Televison & Video
