20 Most Recent
Samsung LN-R328W 32 in. HD-Ready LCD Television Questions & Answers
Samsung LA32R71B
first of all what area are you living in in Philippines 220v as there is voltage rating differences in Dubai
Djibouti 220v
Dominica 230v
Dominican Republic 120v
Dubai 230v
64 other voltages. 50Hz
the board will be set for country of origin, this could mean the power board can be getting more than the ratings need, there will be voltage regulating chips on the power board, main voltage can handed depending on the chip installed up to 600 volts but the other parts cannot handle low voltage or high voltage, this could mean a spike in voltage may not blow but it may weaken the voltage out. i.e capacitors- voltage regulators or even diodes. these have to be checked.
Samsung LN-T3732H 37" LCD
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Green spots on screen of Lcd
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD are given. You can compare it to that of your TVs' and can make sure about the fault.
No picture on samsung lcd tv
I have the same problem. I brought a Samsung 46" in July 07 and on Jan 8, 2008, video went blue.
I called Samsung and sent out technician and they replaced the motherboard.
Two hours later, same problem occured. I called today and Electronic Company thinks I have a bad LCD panel.
Samsung lcd with built in freeview, changes the source on its own, remote not working either
Check its panel control switches. Replace the panel control board. Visit the site named '
Electro-help' for more
details. Click this
link. View it in
Timeslide" or
"Flipcard" option, which can be selected
from the drop down box menu by the [
Sidebar] tag, at the top left corner
of the display window. You can also
click the [
Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
