Durabrand DU1301 TV Logo
A
Anonymous Posted on Mar 08, 2014
Reset v chip - Durabrand DU1301 TV
Resetting epson r1900 ink cartidges
Use a Cartridge Reset Tool
For some Epson printer cartridge models have no reset buttons. Instead the chip's metal contacts need to be pressed specifically at the same time. First, look for a reset tool that is compatible with your cartridge model.
1.Uninstall your empty ink cartridge.
2.Position your ink cartridge where the chip's metal contacts are displayed to the pins of the rest tool.
3.Press the reset tool to the cartridge and allow the tool's pins to press the metal contacts of the of the cartridge chip.
4.Wait for the tool's light to go green. When the green light starts to blink your cartridge chip is now resettled and ready to be reused.
Manually Reset Cartridge
·Turn off the printer and remove all cartridge
·Clean the contact copper chip using a lint free cotton cloth.
·After cleaning the contact chip, reinstall it and then restart the printer
Follow more steps to reset the Epson printer ink cartridge.
Clp320 reset counter
If you are worried about opening the printer or welding, you can simply buy an easy reset chip from Amazon or eBay. No welding is required and the installation takes only 1 or 2 min. Just peel and stick the chip.
Search for DRUM RESET CHIP or PEEL STICK DRUM RESET and you will find many premade reset chips.
If you are familiar with soldering, you may buy a drum reset fuse only and save $$$.
WHY NEED TO REPLACE IMAGING UNIT IN CLP PRINTER SERIES 320
2answers
How to reset toner of samssung laserjet scx4200 after refill
usual the reset will be done automaticaly when you renew the cardrige (from samsung) hte new chip on the cardrige will giff the information to the computer and it will be reset. If you purchased the cardrige from an refilling stor they need to replace the chip also but some times they do not use the right chip so there are some informations missing and the computer can not reset, ask the store keeper to attach the right chip for your samsung printer.
2answers
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
7helpful
4answers
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
2answers
How to reset chip economically
Economics - cheaper to clone the chip, than to spend time and resources cracking the Dell "code." Cartridges are $20.00 each on eBay, is that not cheap enough?
1helpful
Hi How i could reset my epson r230 printers chip? thx in advance
the printer chip cannot be resetted but the device to reset the cartridge chip is available in the electronics market its called compitable epson chip resetter for cartridges.
1helpful
2answers
Reset chip
could you be any more vague?
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
