2001 Ford Escape Logo
Posted on May 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Ford Escape Rear Hatch won't unlock
The rear hatch won't open. I understand that I need to replace the Door Lock Accuator. How do I open the hatch when it won't unlock though to replace it? Is there a button somewhere or manual lever? There is NO key hole.
  • gerry bissi May 11, 2010
    Isn't there a handle above the license plate?
gerry bissi
Level 3:
  • Ford Master 4,390 Answers
  • Posted on Jun 14, 2009
gerry bissi
Ford Master
Level 3:
Answers
4390
Questions
Helped
3060817
Points
11499
The liftgate consists of the following components:
  • liftgate door lock actuator
  • liftgate lock cylinder (if equipped)
  • liftgate window glass
  • liftgate window latch/ajar switch
  • liftgate window glass release handle
  • liftgate latch remote control which consists of the following component:
    • liftgate release handle
  • liftgate latch, which consist of the following component:
    • liftgate latch door ajar switch
Liftgate Latch Actuator Removal and Installation
  1. Remove the liftgate latch remote control. For additional information, refer to Liftgate Latch Remote Control in this section.
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
  1. Remove the liftgate trim panel.
  1. Disconnect the liftgate ajar switch electrical connector.
  1. Disconnect the liftgate latch actuating rod.
    1. Open the clip.
    1. Disconnect the actuating rod.
  1. Remove and discard the liftgate latch bolts.
  1. Remove the liftgate latch.
  1. NOTE: Make sure the liftgate latch release rod is not preloading the latch. It should be clipped in a relaxed state with no slack.
    NOTE: Position the liftgate latch release rod by pushing outboard to remove the slack.
  1. Remove the screws and the liftgate latch actuator
  • Mike OSullivan Feb 21, 2016
    To open hatch refer to this video, all are similar to open when latch solenoid goes bad.
    https://www.youtube.com/watch?v=BKXGgQYX...
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Jan 12, 2009
SOURCE: door ajar alarm
The doorlach pin is faulty.
On newer vehicles it is inside the door on the locking mechanism.
It is stuck in the closed position, or has become dislodged.
Refer to your mechanic for repair.
Anonymous
  • 776 Answers
  • Posted on May 27, 2009
SOURCE: handle on rear hatch door broke off.how can i open hatch door until i can get a new handle?
you don't. take it into a Hyndai Dealership and have the handle repaired/replaced. The rear hatch panel/cover has to be removed (from inside the vehicle) to access the hatch latch and open the door.. from that point the handle can be replaced/repaired.
juggernautxt
juggernautxt
  • 145 Answers
  • Posted on May 02, 2009
SOURCE: electronic lock on rear hatch of 2002 ford escape will not open
the unlock or popper for the door needs to be replaced. the door should work with a key.
Lexdiamonzz
Alex
  • 203 Answers
  • Posted on Jun 12, 2008
SOURCE: HHR back hatch problem
It most likely will be the fuse for the hatch, I would definately check out the fuse before trying other things. If the fuse is ok then it could be the release motor on the hatch.
Good luck..
Anonymous
  • 1986 Answers
  • Posted on Aug 14, 2009
SOURCE: Back hatch will not unlock/open
you could use some lithium grease and spray it in the general area of the latch and hope it lubes the latch enough to loosen it to open. but it will cause a mess spraying it
2answers
Rear hatch and glass 2008 Kia Sportage
you would need to strip out the parts and test for which one is the cause
4answers
2002 FORD ESCAPE
i would suggest you to change that part fully and not wait till it becomes useless.
How do you open the back door (no manual)
Rear hatch is locked or unlocked with a key. (if equipped) • To open the rear hatch, insert the key into the lock, turn it to the unlock position and pull up the rear hatch by pressing the handle (DOOR). You can also lock/unlock the latch (but not release it) with the central door lock system. • If unlocked, the rear hatch can be opened by pressing the handle (DOOR) and pulling the hatch up. • To close the rear hatch, lower and push down the rear hatch firmly. Make sure that the rear hatch is securely latched.
Why can't rear hatch be opened?
Won't open with the key ? Do all the other doors lock an unlock ? You have to understand the electronics involved , you have a remote keyless entry module an all switches are an input to the (RKEM) , an from the voltage input it knows what door to open or unlock or lock . First you would need a wiring diagram to test the circuit an you need to pull the inside panel off the rear hatch to get at the motor to see if the power is getting to it. Can be a very time consuming job. Here check out this video ,it's not the same vehicle as yours but it will give you an idea of what's involved . 2008 2012 Ford Escape Liftgate Latch Won Open Access Diagnosis Repair
6helpful
How to repair rear actuator for ford escape hatch
Bad lock actuator: (NOTE: If your hatch is locked)
First remove rear panel- pull the plastic panel at the top center, until (2)clips pop off, then pop (2) more clips at the mid-center. Stick your arm down until you reach the lock, with your fingers, feel for the squishy plastic( inside is the bar that goes up to unlock), it is attached to the lever to unlock. Pull up the lever until you can open the hatch. There are four more clips at the top sides and middle sides, and four plastic screws at the bottom which is only accessible when the hatch is opened.
The lock is only sold as an assembly at $100.
Part Number #9L8Z-7843150 B
2helpful
2001 Ford Escape rear hatch and window won't open all the time
sounds like the system needs lubricated you'll have to remove door panel to access the rods as well as the lock mechanism clean off an lub check for any bent or loose parts rubbing
Rear hatch door in ford windstar-mechanism came apart
My back hatch would not open but it appears the lock was sticking and the return spring to the handle is broken. We used the key to unlock the back door and then door opened. Then husband sprayed WD 40 in all the lock holes. Now once we open the door we have to push the handle back down as return spring is still missing but the door opens :) . My van is a 2002 Ford Windstar.
Electronic lock on rear hatch of 2002 ford escape will not open
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
