HP LaserJet 4600dn Color Printer Logo
Randy Palmer Posted on Jan 16, 2014
Yellow tint - HP LaserJet 4600dn Color Printer
John Tackett
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 17, 2014
John Tackett
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
1514
Points
9
Yellow tint on a laserjet printer is typically a sign of ink cartridges running low. i would attempt to change those first, if that doesn't work, try cleaning your jets by wiping with a cotton swab dipped in alcohol (first remove ink cartridges so they dont get damaged. also, allow to dry completely before reinstalling ink)
I have a Christie LX100 Projector when projecting a white image there is some yellow tint. Is this something that can be fixed?
If the yellow tint is uniformly over the whole screen then try changing the video colour tint, hue, phase and other chroma related settings in the menu.
3helpful
1helpful
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
1helpful
We have a yellow tint in the picture, it is worse
Yes, It could be either your video board or your dmd board, go to the service menu and if the yellow tint is still there, it's your dmd board, if not it will be your video board
My hdtv has a yellow tint to it.is my bulb going bad?
i think not yet.the circuit for that has faulty parts.try bring it to a tech.
1helpful
Yellow and black tint
From your description. It sounds klike you have some bad glycol or fluid in one or more of the picture tubes. to repair this the glycol can be replaced. To do this is a complicated proceure that requires the tubes to be removed. one the glycol is replace it has to be aligned something that not all that easy At our shop this repair would averge 375 to repair
2answers
Yellow Tint on Lower Right Side of Sony KDS-R60XBR1 TV Screen
Hi, Sony will repair your TV free of cost for yellow tint problem. Click Sony Support for details.
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
10helpful
2answers
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
k24674
Grand Canyon Tech
Grand Canyon Tech
