Kindle entirely depends upon WiFi to access the internet. Following are the few simple tricks you can try one by one to fix the Kindle Won't connect to wifi error.
Refresh the Kindle Device
Switch Router
Distance of Router and kindle
Must select the 1-11 channel
Connect your kindle with the 2.4 GHz band
When you connect to Wifi and if it shows "obtaining IP address" means it is searching for the IP address of the wifi sender...
when you connect to internet it is done through IP address so your phone is tying to locate an IP address with which it can connect
to the internet. Below are the steps to connect your device to Wifi:
Applications-->settings-->turn Wifi ON-->select the wifi that you want to connect from the list displayed-->enter the network password(if it asks for) -->connected Another easy way...just open the chrome app in your phone and try typing in some website like google.com when it tries to connect a pop up will appear "try connecting to WiFi ..mobile data will incur charges.." something of that sort...and you can click connect to wifi...and automatically it will detect the wifi that is around your location. You can check for your IP address through Ip-details.com
It's done in software. go through the menus, look at the options, and select wifi on or off at the appropriate place. (pressing the 'home' button might be a good place to start) I keep wifi permanently off on my kindle. It might make a difference as to which version of the kindle you have because the way you do this almost certainly depends on that. It may lead to more more helpful answer if give the version of the kindle you have.
see this video
Just two examples !
23.June.2015
So livebox is some sort of internet provider? Is it WiFi? If so then the kindle would connect just like any other wifi device like a laptop or smartphone. You need the SSID of the wifi device and the password.
well maybe did you change your wifi password because that happend to me and then i rembered i changed the password for my wifi i hope this helped if not im sorry .
