20 Most Recent Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Questions & Answers
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
Proscan... | Answered on Jan 03, 2020
It could be either the charger, the cord or the tablet. Do you have another charger to test with?
Proscan... | Answered on Jul 13, 2015
As a battery ages it may be unable to charge completely. It may be time to replace it.
Proscan... | Answered on Sep 11, 2014
You could go to a phone repair store, but perhaps to repair it, will cost more than a new one. So before you hand it over for a repair, ask what it will cost.
Proscan... | Answered on Aug 25, 2014
Cracked screen cannot be repaired. It has to be replaced with a new one of similar type and number.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
First you must know what format your tablet can play. Not all MP4 formats are the same. Perhaps you even have to install a video player app.Then you have to convert all content to the format your tablet can play, and then you can copy it to the tablet, using a cable, or an SD card. (if your tablet has a slot for that)
Proscan... | Answered on Jul 21, 2014
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Proscan... | Answered on Jul 09, 2014
Should be on the edge right next to the power button.
Proscan... | Answered on Jul 02, 2014
If that is the case, you must bring it to the technician they know how to unlock your tablet, it is same thing with the cellphone.
Proscan... | Answered on Jun 30, 2014
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
PROSCAN customer support telephone number is. 1-888-977-6722.
www.oncorpus.com.
Proscan... | Answered on Jun 23, 2014
i have locked myself out of my tablet PLT7045k
I assume you ant to connect your tablet to the internet.To do so, yu need a hotspot, or a router with internet access. That could be in a public place (starbucks) or at home. But when you want to connect at home, you have to create your own hotspot to the net. Try to contact a provider, to find out how you can connect to the net. Cable DSL, or even with 3G or 4G.
Proscan... | Answered on Jun 06, 2014
Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Logo
139 questions posted
Top Proscan Tablets & eReaders Experts
 Mike M
Mike M
Pollo
Level 1 Expert
Harrie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Tablets & eReaders
Most Popular Question
volume button
  • Tablets & eReaders
