20 Most Recent Proscan 8 4GB Android 4.1 Tablet Questions & Answers
Not being able to update any apps simply means either you don't have access to the internet or that your apps update is programmed to function ONLY when you are connected to/through WiFi.
second, you can download standalone 'raw' apk files online and install on your tab.
Remember to go into your Settings---Security (and under Device administration, check 'Unknown sources' and activate 'allow installation of apps from unknown sources'.
Done.
This is safe.
Post update or feedback please
Proscan 8 4GB... | Answered on Oct 11, 2017
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Proscan 8 4GB... | Answered on Feb 15, 2017
Hi Brenda, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Proscan 8 4GB... | Answered on May 08, 2016
Try holding the on/off buttom and the volume buttom down at the same time til you get a reading across the screen promote you what to do next. This should reset everything and let you back in. ( make sure you hold both the up and down at the same time on the volume) good luck and i hope this works just about all eletrice have a soft and a hard reset.
Proscan 8 4GB... | Answered on Dec 02, 2014
When you press and hold in the power button it should boot up. If it doesn't the battery might be dead so charge it up and try again. If it doesn't boot up after charging we need more information.
Are you getting any kind of a screen or just nothing?
Proscan 8 4GB... | Answered on Oct 26, 2014
Press power button + vol up + vol down and release power button in boot logo and hold volume buttons.
Proscan 8 4GB... | Answered on Apr 27, 2014
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Have you tried the pinhole reset?
Proscan 8 4GB... | Answered on Apr 13, 2014
you may need to do a factory re-boot to try fix it
Proscan 8 4GB... | Answered on Dec 29, 2013
sorry Fixya DID NOT SELL YOU ANYTHING
Proscan Tablets... | Answered on Dec 24, 2017
Proscan 8 4GB Android 4.1 Tablet Logo
Popular Tags
50 questions posted
Top Proscan Tablets & eReaders Experts
 Mike M
Mike M
Pollo
Level 1 Expert
Harrie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Tablets & eReaders
Most Popular Question
dis factory reset proscan 8 plt8235g
  • Tablets & eReaders
