20 Most Recent
Amazon Kindle 1 Questions & Answers
My kindle screen no longer works.
if they sidebar works and you don't have an image on the screen, you definitely need a new screen. Amazon should give you a free replacement. If you're out warranty, you can get the part at
Kindle Repair and there is a guide that shows you how to open a kindle and install parts at
Kindle Repair Guide.
My kindle wont turn on
If the kindle won't turn on because it was recently dropped or water was spilled on it or something, you should consult your warranty. If this is due to no external event/damage you should call amazon and see whether or not there's an update in software or a bug of sorts. If it's on their behalf you'll get a replacement device. Good luck!
I would like an app t read kindle books
Hey there,Leawo Prof. DRM is dedicated to removing different types of DRM including videos,musics audiobooks in iTunes and then convert to the common format what's more, it also support to convert DRM-locked ebook to epub format to read on different Ereader including Sony Reader, BeBook, IREX Reader, iPhone, iPhone, iPod, iPad, and Nook from Barnes & Noble's.Check this guide
Can Read Kobo eBooks on My Kindle
Wi-fi- error
Hello friend...
Refer to your Internet service provider, if they provided your wireless router, or the router manufacturer, for additional help. Restart your Kindle and modem and/or router. Press and hold the Power button on your Kindle for seven seconds until the Power dialog box appears, and then tap Screen Off.
My kindle screen is distorted model number D00901
Dear Sarah,If your Kindle presents some horizontal or vertical lines in part of the screen, or even in full screen, and if the image is kind of "vaporous", not bright, it might have happened that you have a broken display (maybe due to pressure exerted on it, by something inside your bag, backpack or wherever you carry your Kindle). Please check this link to see if your problem is similar to those shown in the images:
https://www.google.com.br/search?q=broken+kindle+display+image&client=opera&hs=72G&tbm=isch&tbo=u&source=univ&sa=X&ei=hsZ5Upr2PMrqkAez1YHwCw&ved=0CCgQsAQ&biw=1280&bih=730If that is the case, you can buy a new display from Ali Express and replace it following the disassembling instructions shown at http://www.ifixit.com/Guide/Repairing+Kindle+3+%28screen+replacement%29/11938If you do not want to do it on your own, take the display and the instructions provided in the link indicated to a service technician that you trust and have it replaced (I had the same problem with my kindle 3 and replaced its display in less than an hour - it is not that difficult...).Although you posted the problem in the area for the Kindle 1, by the model number it seems that you have a Kindle 3 (3rd generation) or Kindle Keyboard. The display for this model is the one shown in the link below:http://www.aliexpress.com/item/Kindle-Keyboard-Wi-Fi-6-E-Ink-Display-ED060SC7-100-Amazon/418068038.htmlHope it helps!Regards,Miguel Luiz Martins
My Kindle won't turn on after I charged it. I charged it because the 2 books I bought did not show on the kindle.
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If the
Kindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
- Make sure the Kindle is turned ON.
- Press the Power button for 20-30 seconds until it turns OFF.
- Wait for it to reboot, if it doesn't press the power button to turn it ON.
- Your kindle should be back to a responsive state. hope this helps
How do I register it?
Swipe down from the screen tom on main menu and you will seea help button with FAQs.
