Kyocera KM-1505 Copier Logo
m
monika pandey Posted on Dec 13, 2013
Error c6020 - Kyocera KM-1505 Copier
Pansolutions Tzaneen
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Dec 17, 2013
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
16621
Points
35
This is a fuser error. go into service mode( in the copier standby press 10871087 on the keypad) and go to u163 fuser error reset. If this does not work you might have to consult a service centre.
Kyocera taskalfa 1800 showing c6020 on the screen
Thermister failure or too much heat.
Kyocera TASKalfa 1800 - Error Code
Printcopy.info https://printcopy.info > model=TASKalfa 1800
Code: 6020; Description: Abnormally high fuser thermistor 2 temperature (Center) Fuser thermistor 2 detects a temperature higher than 210°C/410°F.
More help and videos
https://www.google.com/search?q=Kyocera+taskalfa+1800+showing+c6020
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Code c6020 180
That is a fuser error. Replace the fuser & reset the code in service mode. You will also want to update the firmware of the machine.
1helpful
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
How to fix code C6020 of kyocera km1820
how to fix error c6020...1st step is go get a gasoline and a match and then pour the gasoline to the kyocera and then lit it with your match stick...it will automatically restart..for more details contact your kyocera supplier.
12helpful
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
14helpful
2answers
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
1helpful
Error code C6020
Sounds like you have a faulty thermistor. (heat sensing device) The 6020 indicates an abnormally HIGH temperature. If the readings are greatly different in the two thermistiors or one is not touching the hot roller could also be the problem.
2helpful
2answers
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
