20 Most Recent Kyocera KM-1505 Copier Questions & Answers
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Kyocera KM-1505... | Answered on Nov 22, 2019
my dear you press 10871087 after you press 163 and start baten
Kyocera KM-1505... | Answered on Sep 14, 2019
bad laser scan unit
Kyocera KM-1505... | Answered on Nov 08, 2018
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Kyocera KM-1505... | Answered on Jul 24, 2017
it may be the problem of moisture dont worry take brasso(used for shining the mitallic products) and put out photo conducting drum and clean the dum with brasso by using a soft cotton cloth ur problem must be solved
Kyocera KM-1505... | Answered on Dec 09, 2016
this is a fuser error. go into service mode( in the copier standby press 10871087 on the keypad) and go to u163 fuser error reset. If this does not work you might have to consult a service centre.
Kyocera KM-1505... | Answered on Jul 27, 2016
what you want reset befor tell me i help you
Kyocera KM-1505... | Answered on Aug 02, 2015
my dear your ram promblem DDR ram
my dear your LD unit problem or board
Kyocera KM-1505... | Answered on Jul 08, 2015
remove paper
Kyocera KM-1505... | Answered on Jul 04, 2015
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
Kyocera KM-1505... | Answered on Jan 17, 2015
UF means that the dev unit connector is removed or insert the toner container further inside
Kyocera KM-1505... | Answered on Oct 31, 2014
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Kyocera KM-1505... | Answered on Aug 18, 2014
check to see if someone broke a sensor when removing a jam that's the first thing too check
Kyocera KM-1505... | Answered on Jul 02, 2014
Don't Worry, It's simple ! You Just have to do is:
1)Buy a toner Bottle, its dust and be careful with it.
2) Pull out the toner Cartridge (You know where it is?)
3) There is a small cover with a screws , open it and remove all dust inside.
4) Fill with new ink and screw up the cover,
5) put cartridge back on printer and start.
Enjoy ! write back if any problems.
Kyocera KM-1505... | Answered on Jun 30, 2014
AP means ADD POWDER, actually add toner.
just check the toner cartridge maybe the toner is empty if its empty just replace a new one
Kyocera KM-1505 Copier Logo
217 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
solve error c4000 kyocera km 2035
  • Office Equipment & Supplies
