20 Most Recent Kyocera Copystar CS-1820 Black and White Copier Questions & Answers
Change the SMTP port from 25 to 587
Kyocera Copystar... | Answered on Jun 27, 2019
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Kyocera Copystar... | Answered on Mar 26, 2019
This means the Smtp server settings is wrong.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera Copystar... | Answered on Feb 06, 2019
The only way to reset the password, is to use the Paramter "U 24". Thus the harddisk will be formatted!
Kyocera Copystar... | Answered on Nov 11, 2017
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Kyocera Copystar... | Answered on Oct 20, 2017
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
Kyocera Copystar... | Answered on Sep 13, 2017
What to do if the current display is "Machine Failure Call Service C7990" but few days ago it displays "Toner Waste Box is Full".?
Kyocera Copystar... | Answered on Mar 11, 2017
solenoid stucking, modify or replace 082 396 8206
Kyocera Copystar... | Answered on Apr 18, 2016
fuser temperature over /under u need service engineer to reset it
Kyocera Copystar... | Answered on Mar 31, 2016
scanner home position sensor error. has to do with the bright light and mirror assembly that moves back and forth under the glass. DANGER high voltage present
Kyocera Copystar... | Answered on Feb 07, 2016
Read the manual. Usually unplugging for 1 minute and plugging back in will resolve issue. Check paper track to see if there is any debrea clogging the machine.
Kyocera Copystar... | Answered on Nov 12, 2015
my dear you chek toner or drum is weak
Kyocera Copystar... | Answered on Jul 08, 2015
Scanner related
=Check if the scanner lock(transportation) is on(should be off).
=Clean inside the scanner.Mirrors and lamp.
Kyocera Copystar... | Answered on Jan 14, 2015
First (the priceless solution) clean the feed roller and the separator kit using a piece of cloth (not paper) and glass cleaner or alcohol.
Otherwise replace the 2 solenoids (feed and regist) and probably the separator kit
Kyocera Copystar... | Answered on Oct 11, 2014
backup memory error. reseat dimms
Kyocera Copystar... | Answered on Sep 30, 2014
By calling the crevice centre in your manual. sometimes the number is on a card attached to the printer. If you call the centre, tell them what copier you have, what the code is and they also will ask how many copies are made. So write that down before you make the call.
The service centre probably will send a mechanic, to repair the error.
Kyocera Copystar... | Answered on Jun 25, 2014
Kyocera Copystar CS-1820 Black and White Copier Logo
275 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
copystar cs 1820 black and white copier
  • Office Equipment & Supplies
