Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
Posted on May 11, 2009
My computer crashed yesterday and I had to reset the CMOS
I got my computer back up but now when I try to scan a document into pdf format, it is a jumbled mess.  Any idea how to reset the scanner?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
61
Points
Cancel all of your scanning request and reboot your printer. this may help.
How do I name and save a scanned document in HP C4480 (Windows)?
Hello, Robert -
I hope I am correct in assuming you have the user's manual for the HP Photosmart C4480. Just in case you do not, this is the link to the web page where you can download and save the manual (PDF format - Adobe Acrobat Reader software needed, free):
https://support.hp.com/us-en/product/hp-photosmart-c4400-all-in-one-printer-series/3655558/model/3655559/manuals
After downloading the PDF document save it (Save As) to your Documents folder and give it a name you can find again easily - maybe: HP Photosmart C4480 Manual.
How to save a PDF file:
- With your computer, open the PDF document in Adobe Acrobat Reader
- Move cursor to upper left corner of page and left click or tap on FILE
- In drop down File menu, move cursor to SAVE AS and left click or tap on it
- In Save As window which opens, move cursor down to CHOOSE A DIFFERENT FOLDER and left click on tap on that "button"
- In window which opens choose DOCUMENTS in the Documents Library
- In File name box near the bottom of the Documents Library pop-up window, enter the name with which you want to save the PDF document, Example: HP Photosmart C4480 Manual
- Left click or tap on the SAVE button
Note: The steps above will be similar to what you will need to do after scanning any document.
The instructions for scanning start in Chapter 10, Page 64 (Image 304 of the PDF format manual).
Open the scanner through your computer. It is easier to save the document later by operating the scan functions through your computer.
With the scan application open on your computer run the scan process. After scanning the document, you will need to save it. First, you will need to determine the format in which you want to save the scanned document: PDF, JPEG (photo image), GIF, etc.
After choosing the format for the scanned document, in the proper file name box, enter the name for the document you wish to save.
Examples:
Correspondence 2018-Feb-18 Brother
Photo Brothers-Family 2018-Feb-18
Deed of Sale 2018-Feb-18 House
Get the idea? I like to give a date to my scanned document names to help identify them better.
Once you have entered the file name, click or tap on the SAVE button.
Note: I always like to open the saved document from the Documents folder to verify it was saved. Plus, my scanner attaches a number at the end of every file name. After closing out the saved document and closing the scanner winder, I go back and Edit the file name, removing the added number (digits) from the saved file name.
The video you will find with this link:
http://esvideo.es/video/watch/ult2ORqN1eGRiLQ=
is for those who use Windows 8 or 10. Even if you use another Windows operating system (I use Windows 7), you can probably figure out what to do. The video goes through the scanning and saving process step-by-step.
Best wishes.
1helpful
Why do scanned documents only display in PDF format. Why not display in WORD?
well scanned documents are best suited with pdf format since a photo scanned would lose its glamour in a word document format and thus looks good in a pdf format but there are still options for you to convert it to a word document through: http://convertonlinefree.com/PDFToWORDEN.aspx
2helpful
Save scanned document in pdf
Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
1helpful
3answers
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
When i email scanned docs from my HP officejet 8500 Plus printer to my email, the pdf's are too large. how do i set them to be emailed at a smaller size.
No problem, you can solve this problem very easily :
Whenever you scan a document directly to your e-mail in a PDF format then printer scans it using its own property and only scans the document without any editing in the font or characters.
But the output i.e. the scanned document in pdf shows the same text using its own properties. That font is selected by pdf and not by the hp software.You can open the scanned pdf file and manually change the font size.
Or else
The best way that I will suggest you :
- First scan the documetn in a pdf file or any format on your computer instead of directly on e-mail.
Because when you scan it to your computer printer will scan the document directly to computer and in this way after scanning you can open and see the document. You can make sure if it is scanned properly or not, however when you scan it to e-mail there are chances when we dont verify if the document is scanned properly or not. If there is any hardware issue or any other error then it will scan half page or a blank page....we wont be able to verify it.
- Also if it is an official document which is half scanned or has some problem in it will give a bad impact on the receiver which is not good for professionals.
- By scanning on computer you can verify the document, can make required changes and will be able to send the document in a proper way. It is going to take few seconds but results will be fruitful....try it..!!! I do the same way and there is not much difference
How can I scan a document into the WorkCentre M20i so that it is emailed as a word document and not a PDF doc. When we scan a document it is emailed as a PDF document.
You can not email documents on word format directly fromt he device.
PDF and image formats such as tiff and jpeg are the only formats you can scan.
A word document is a raw document that as been modified and formated by a specific text processor, in this case MS office. And the decive does not contain this processing capabilities.
My HP F4210 can´t create PDF format from scanned documents. I run VISTA. Stefan
It's not the scanner that creates the PDF, you need scanning software capable of saving scanned image as PDF. loaded on your computer. The software determines where to send and how to save a scanned document.
Cannont scan to PDF or RTF with HP PSC 2410 All-In-One InkJet
You have a problem with your scanner software or your operating system.Try connecting you scanner to another computer, install the software, and try scanning.
Norman Weimar
Norman Weimar
k24674
