SOURCE: How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
u ahve go with a good repaier
SOURCE: Acer Aspire 5630 - CMOS Jumper?
You can use a screwdriver to connect the 2 points of the cmos jumper for a few seconds. The default password is blank password.
Gerard
SOURCE: where is the CMOS battery located on Acer Aspire
Bottom of the laptop, the big cover that comes off. Below the wlan card
SOURCE: How do I remove keyboard on acer aspire 5510
Underneath your laptop there should be to screws with a small logo of a keybord remove the screws then gently lift the keybord with caution as there maybe some retaining clips holding it in place, then remove the cable by sliding the retaining clip out,
SOURCE: Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Before you start 1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need. 2) Purchase the battery through Acer or a local or online computer parts dealer. 3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices. 4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge. Removal of the CMOS battery Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. The battery should look something like this
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
