20 Most Recent
Acer TravelMate 2300 Notebook Questions & Answers
Acer travelmate bios reset
you need to unhook, your battery on your main board it is usally on the bottom of the laptop,once you unhook the battery you need to keep it unhook for about 15-30 minutes then put it back together
and then reinstall your windows it is quite complicated back take the lap completey apart that is the only way to get the bios password out ... hope thie helps lala linda
BLU RAY TROUBLE
From what I have researched, your laptop should have come with software to play Blu ray - such as Intervideo WinDVD BR
The software is not available to the public and only comes with such laptops and blu ray drives.
Hope I have helped
G'luck
My DVD wont play on my laptop..
Will it play in some other computer?
Will it play in a DVD-player?
Is it just one DVD that will not play,
or will _no_ DVDs play?
What software (Windows Media Player, PowerDVD, VLC, other) are you using as your DVD-player controlling-software?
What error-message(s) do you see?
Manual for the aCer aspire 5520 model# ICW50
Hey,
Here is the user guide for aspire 5520
You will need to open a new internet page, and copy this text fully into the addressbar to download the guide, starting with ftp:
ftp://ftp.work.acer-euro.com/notebook/aspire_5520/manual/Aspire_5220_5520_5520G_EN.zip
The zip file has the pdf format manual inside, if you can't open it let me know.
Msn tech support number
For account/password issues of free MSN Hotmail users, you may visit this website
https://support.live.com/eform.aspx?productKey=wlid&ct=eformts&scrx=1
Fill out the service request form on the website, then submit your querry. MSN Hotmail Support will be able to help you with your account issue. Also, if you are an MSN subscriber, they can give you the MSN Technical Support Hotline number.
At the moment, the free MSN Hotmail service provides technical support via e-mail only.
Hope this helps. =)
Travelmate 2300 won't power on
The problem could be your bezel. Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open) once removed, press the button on the motherboard under where the power button is. If the unit still does not power up, then your motherboard is bad and needs to be replaced. If it does power up, you need to replace the bezel.
Bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Windows Vista X64 Drivers
Try this website and see if it can help you
http://www.opendrivers.com/modeldriver/Acer_notebook_Aspire%207720-driver-download.html
I need to download the drivers for home choice laptop because it gives me problems about showing the usb
The drivers are normally part of windows system and as such are not needed, but if you are still with XP, then that may be the issue as support for XP has totally finished as the unit is so old it is now "end of service life" which means Acer do not support the unit for any reason as well, unfortunately i don't know of anyone who might be able to help unless you do try Acer tech and see what help they might be able to offer.
Reset travelmate 2300
You need the original recovery disks that came with the unit as there is no built in recovery. If you have none then you will need to purchase a copy of windows or contact your regional Acer office whereby you can purchase a new set of original disk (bearing in mind this will be XP as you will not be licensed for any other version).
