There is a error on the printer that states c-3508 and it paper jams as soon as it coms out of the registration assembly. it paper fan folds before it touches the transfer roller before the fuser.
Sir/Mam,
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: media jam transfer roller
Hello pp-helps,
This is very interesting. I do have the very SAME problem with my Xerox 6120 printer. I've been looking for the fuser roller all over without any sucess. The new fuser unit costs approximately the same as a new printer. I'm frustated at this time. I want to ask you the following: Are the mechanical components from the 2430 exactly the same as the 6120 as far as the fuser unit goes? if I find a roller replacement for the 2430 will it fit my 6120? do you have a p/n by any chance or know where can I get it?
I really really appreciate your help.
Regards,
Frank
SOURCE: Paper jam at transfer roller with no paper jammed
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
SOURCE: Paper jam
I same problem.. I hadn't used my one i months. tried printing and would only feed the paper in and make folded paper inside.
I fixed it by the damp cloth on the feeder roller. Not the bottom roller but the main one in the middle. I had to roll the roller abit. when I was rolling it it had fluff come through from the main roller that touches the drum. So roll the middle roller with your fingers and wipe.. keep doing it as it's rolling the the larger main one. will take a while until you get all the dust and fluff out!
SOURCE: Konica Minola 2300DL laser printer. When I try to
I would closely examine the exit roller. When the paper fans; it's sticking on something. Typically, stuff will ":hide" on rollers; or maybe stuck on a sensor. Using a good flashlight will help.
SOURCE: My Konica Minolta 2530DL printer has paper jam ,as
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
IF YOU HAVE A TRAY 5, ITS MORE RELIABLE
IF STILL PROBLEM HAVE YOUR TECK USE THESE PARTS
A03X565300 FEED AND TAKE UP ROLLERS
A03X565400 SEP ROLLER
56AA82012 BOTH CLUTCHES
AND TRY UNPLUGING TAKE UP ROLLER PICK UP SOLIENOID, WELL IT SHOULD WORK BETTER, AND MAKE SURE YOU DO THE BOTH SIDE ADJUSTMENT, WITH OUT SEEING EXACTLY WHAT THE COPIER IS DOING THIS IS MY BEST ANSWER
