20 Most Recent
Konica Minolta bizhub 180 All-In-One Printer Questions & Answers
I have message call service(M1) So how to clear
go to service mode,
press utility button from the panel, now press " stop, 0,0, stop, 0,1,
it will show service mode,
now select shipment,
in this option, select "Maintenance Counter"
now in this option select, 0
and press ok.
Error message M1
Press Utility / Counter -> {STOP}{0}{0}{STOP}{0}{1}, now you should be in Service Mode. Go to Service Choice - > IU LIFE STOP MODE -> and choose CONTINUOUS.
My konica minolta bizhub is showing toner finish even after replacing a new toner
Sir/Mam
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
