SOURCE: My Garmin Nuvi 250 GPS power and USB connector is
you will have to open the unit and solder it back to the pcb board. This is a difficult job and requires some knowledge of working with micro size components. You will need a magnifying lens preferably one that is hands free and strong, a fine point soldering set up, a #5 screw driver set with star and philips tips. There are 2 screws on the back lower area under the label. You can buy plastic tools to open the case. Be careful. separate it slowly all the way around. There is a ribbon wire connected to the lcd so don't rip it open. Remove the screws on the pcb board connecting it to the back case. Unplug the speaker and the battery. Good luck.....
Insert the memory card into the memory card slot on Garmin
Nuvi 250 GPS device. The memory card slot is located on the left side of the
device. Push the card in until it clicks. (If you inserted a memory card that
already has pre-installed maps and files, there is no further action required.
The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable.
The mini-USB connector will need to be inserted into the rear of the Nuvi 250;
the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin
memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX
formatted Waypoints and other mapping-related files. Right-click on it. Select
"Copy."
Select the "Computer" folder from the computer's
desktop Start menu. Double-click on the "Removable Disk" drive that
represents the Garmin Nuvi.
Right-click in an empty space within the drive and select
"Paste." The files have now downloaded to the memory card and will be
accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
The connector either needs replaced or resoldered.
See this link:
http://www.sharc.net/gps_charger_repair....
- Jim
Exactly what I needed. Thanks.
