Everything works on my product but the scanner mode on the control panel
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click each program to include on the Scan To list.
Click the Add arrow.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
