SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
SOURCE: problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
SOURCE: Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
