A
Anonymous Posted on Sep 04, 2013
Low speed at 33rpm only sony ps-242....? - Sony Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • Sony Master 10,542 Answers
  • Posted on Oct 04, 2019
Franco Dosil
Sony Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379219
Points
178965
Https://www.yoreparo.com/enlace-externo?codeHref=aHR0cHM6Ly9kcml2ZS5nb29nbGUuY29tL2ZpbGUvZC8xQTZyTW1oeWZGN1NMblNJN0NZaExZSFhERTAtczA2Wk0vdmlldz91c3A9c2hhcmluZw%3D%3D&hash=4981dcf39dad0183130fb45eed7055ba
1 Related Answer
Anonymous
  • 42 Answers
  • Posted on Jan 25, 2009
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Panasonic SL-HM42 turntable runs a bit too slow on 33rpm. Hasn't been played in a while. How do I the plate off to check the belt?
Most turntables need you to lift of the matt and then round the spindle is a horseshoe clip which you need to take off.
Istall part 988511772
Assuming that this is a replacement part then Sony don't tend to supply fitting instructions with these as they are meant to be fitted by Sony authorised service people. If it is some kind of special part that can be fitted by members of the public then you can contact Sony for advice. Otherwise you might be best to take it to a Sony authorised service centre and pay to have it fitted. That way you can be certain it will work correctly.
1helpful
2answers
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
1helpful
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
1helpful
Sony ps-lx2 turntable clicks when spinning
Sony ps-lx250h belt-driven turntable runs too fast.
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
9helpful
2answers
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
